RetroWave PS4
Thank you Triantares .
After having done a lot of testing with version 3.8.30. I went back to the Retrowave version. Very nice distribution. Gorgeous.
PS4 port ok.
installation of drivers ok, and kernel 5.15.00 installed.
I'm sharing some screenshoots with you. A Mega link of the Retrowave-PS4 elive system (basic). To install this system, follow this tutorial published by Noob404: Run any PS4 Linux Distro without installing on PS4: Easier Installation Method | PS4Linux
I have not yet blocked updates of installed drivers, and have not installed any programs. For the moment it's working well.
Actually Retrowave initially had a 3.8.30 base and was subsequently numbered 3.8.32 so I'm not surprised you're pleased with it.
It is a very nice Elive version indeed, I agree. :+1:
Sadly it didn't get the traction it deserved, out there on the net.
And it's nice to know it ports well to a PS4 ... Good work and thank you for sharing. :happy_dance:
Hello everyone. I have a little problem. I thought that by blocking the version in synaptic, it would block the updating of certain packages. But if I click on "Elive Upgrader" the updates are only the same. How can I properly block certain packages, without Elive reminding me of these updates.
THANKS
There are quite a few ways of doing that ...... all a matter of preference but IMO marking a package on "hold" is the easiest way.
From PinningHowto - Community Help Wiki
sudo apt-mark hold libxfont1 …
Replace 'libxfont1' with the package(s) you wish to hold.
Dpkg
On older systems, use dpkg:
    Open a terminal
    sudo -s and hit enter
    Enter your password for sudo
    echo libxfont1 hold | dpkg --set-selections
    Replace libxfont1 with the package you want to pin
    Now run sudo apt-get update and then sudo apt-get upgrade
that works.
A little video of Retrowave on PS4 with e16, E25. the video is not of very good quality.
https://youtu.be/515dIZKKVKc
Avé!
De l'AMIIIGGAAA sous Elive sur PS4: Tip-top!
Bravo! :+1:
Arggg: pas possible pour l'heure d'utiliser mes machines Amiga & MorphOS..! :frowning:
Thanks you Franc. Amiga for ever :wink:
Elive Retrowave has found its place on PS4
