The problem doesn't occur if I'm not logged. I have to be logged in either E16 or E24.
And few seconds after I hitted ctrl+alt+F4 the screen become garbled and I seem to stay in the X console (ctrl+alt+F7). And I can't go out of that console even if I retry with ctrl+alt+F4 or another console.
I found these messages in /var/log/syslog that seems related to the problem
Oct 6 16:32:40 localhost systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Oct 6 16:32:40 localhost systemd[1]: closestalledprocesses.service: Found left-over process 22799 (sleep) in control group while starting unit. Ignoring.
Oct 6 16:32:40 localhost systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
I have error messages in my .xsession-errors but I can't be sure they are related.
I'm pasting the interesting part here (the hole file is a longer):
ERR<13364>:eina_safety ../src/lib/evas/canvas/evas_object_text.c:499 _evas_text_efl_text_font_font_size_set() safety check failed: size <= 0 is true
## Copy & Paste the below (until EOF) into a terminal, then hit Enter
eina_btlog << EOF
/lib/x86_64-linux-gnu/libeina.so.1 0x7f2d24218b2c 0x7f2d241ed000
/lib/x86_64-linux-gnu/libeina.so.1 0x7f2d24219c71 0x7f2d241ed000
/lib/x86_64-linux-gnu/libeina.so.1 0x7f2d2421b293 0x7f2d241ed000
/lib/x86_64-linux-gnu/libeina.so.1 0x7f2d242336c0 0x7f2d241ed000
/lib/x86_64-linux-gnu/libefl.so.1 0x7f2d22e1775f 0x7f2d22dfc000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d23703c31 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d23677814 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d2367b20e 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d2367fd15 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d2370c968 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d236feb98 0x7f2d23647000
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d23717fa1 0x7f2d23647000
/usr/lib/x86_64-linux-gnu/enlightenment/modules/battery/linux-gnu-x86_64-dev-0.24.99/module.so 0x7f2d1405cd90 0x7f2d14059000
/usr/bin/enlightenment 0x5583c60e4729 0x5583c6018000
/usr/bin/enlightenment 0x5583c60e52cb 0x5583c6018000
/usr/bin/enlightenment 0x5583c6134ef1 0x5583c6018000
/usr/bin/enlightenment 0x5583c6134fbe 0x5583c6018000
/usr/bin/enlightenment 0x5583c605ef63 0x5583c6018000
/lib/x86_64-linux-gnu/libc.so.6 0x7f2d232f009b 0x7f2d232cc000
/usr/bin/enlightenment 0x5583c60605fa 0x5583c6018000
EOF
eina_btlog << EOF
/lib/x86_64-linux-gnu/libedje.so.1 0x7f2d2367e706 0x7f2d23647000
EOF
ESTART: 1,70045 [0,01597] - battery Done
ESTART: 1,70048 [0,00003] - clock
ESTART: 1,72798 [0,02750] - clock Done
ESTART: 1,72803 [0,00006] - mixer
ESTART: 1,73009 [0,00205] - mixer Done
ESTART: 1,73014 [0,00006] - bluez5
ESTART: 1,73142 [0,00128] - bluez5 Done
ESTART: 1,73148 [0,00006] - tasks
ESTART: 1,73248 [0,00100] - tasks Done
ESTART: 1,73250 [0,00002] - xkbswitch
ESTART: 1,73426 [0,00175] - xkbswitch Done
ESTART: 1,73431 [0,00005] - syscon
ESTART: 1,73545 [0,00115] - syscon Done
ESTART: 1,74254 [0,00709] - E_Shelf Init Done
ESTART: 1,74278 [0,00024] - MAIN LOOP AT LAST
ESTART: 1,75652 [0,01374] - SLEEP
ESTART: 1,86836 [0,11184] - gadcon populate idler start
ESTART: 1,86845 [0,00008] - gadcon populate idler end
RRR: CB screen change...
RRR: CB output change...
CRI<13364>:e ../src/bin/e_hints.c:390 e_hints_client_stacking_set() Window list size less than window count.
eina_btlog << EOF
/usr/bin/enlightenment 0x5583c60e9502 0x5583c6018000
/usr/bin/enlightenment 0x5583c6177175 0x5583c6018000
/usr/bin/enlightenment 0x5583c60740f8 0x5583c6018000
/usr/bin/enlightenment 0x5583c607e524 0x5583c6018000
/usr/bin/enlightenment 0x5583c6081048 0x5583c6018000
/usr/bin/enlightenment 0x5583c610f81e 0x5583c6018000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d241064df 0x7f2d240e7000
/lib/x86_64-linux-gnu/libeo.so.1 0x7f2d241a21b5 0x7f2d24187000
/lib/x86_64-linux-gnu/libeo.so.1 0x7f2d2419aa47 0x7f2d24187000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d24108b91 0x7f2d240e7000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d24109305 0x7f2d240e7000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d2410e8b5 0x7f2d240e7000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d2410dba7 0x7f2d240e7000
/lib/x86_64-linux-gnu/libecore.so.1 0x7f2d241093c7 0x7f2d240e7000
/usr/bin/enlightenment 0x5583c605f0ce 0x5583c6018000
EOF
ESTART: 2,20755 [0,33910] - gadcon custom populate idler start
ESTART: 2,20764 [0,00009] - gadcon custom populate idler end
DEV: CHANGES ... have 12 devices, changed=0
RRR: ... 1 0
RRR: reconfigure screens due to event...
RRR: ................. info get!
RRR: NEW SCREEN ...
RRR: .... out VGA-0
RRR: ...... lid_closed = 0 (0 && 0)
RRR: ...... connected 0
RRR: ...... modes (nil)
RRR: NEW SCREEN ...
RRR: .... out LVDS
RRR: ...... lid_closed = 0 (1 && 0)
RRR: ...... connected 1
RRR: ...... modes 0x5583c8449830
RRR: 'LVDS' 0 0 1366x768
RRR: NEW SCREEN ...
RRR: .... out HDMI-0
RRR: check fingerprint...
RRR: ... fingerprint says 0
RRR: screens lists 3 -> 3
RRR: --------
RRR: --------
RRR: --------
RRR: screens 1 -> 1
RRR: --------
RRR: look at r2 screen ID VGA-0/
RRR: look at r1 screen ID VGA-0/
RRR: skip change because of single laptop lid
RRR: look at r2 screen ID LVDS/00ffffffffffff0030e4f2020000000000140103802213780a05859b5b5494260e505400000001010101010101010101010101010101121b567250000c302428350058c210000019000000000000000000000000000000000000000000fe004c4720446973706c61790a2020000000fe004c503135365748342d544c433100ff
RRR: look at r1 screen ID LVDS/00ffffffffffff0030e4f2020000000000140103802213780a05859b5b5494260e505400000001010101010101010101010101010101121b567250000c302428350058c210000019000000000000000000000000000000000000000000fe004c4720446973706c61790a2020000000fe004c503135365748342d544c433100ff
RRR: look at r2 screen ID HDMI-0/
RRR: look at r1 screen ID HDMI-0/
RRR: --------
RRR: changed = 0
RRR: out id=VGA-0/: connected=0 enabled=0 configured=0
RRR: out id=LVDS/00ffffffffffff0030e4f2020000000000140103802213780a05859b5b5494260e505400000001010101010101010101010101010101121b567250000c302428350058c210000019000000000000000000000000000000000000000000fe004c4720446973706c61790a2020000000fe004c503135365748342d544c433100ff: connected=1 enabled=1 configured=0
RRR: check lid for LVDS...
RRR: out id=HDMI-0/: connected=0 enabled=0 configured=0
RRR: scr: VGA-0/ lid=0 conn=0
RRR: is not lid, is not connected
RRR: scr: LVDS/00ffffffffffff0030e4f2020000000000140103802213780a05859b5b5494260e505400000001010101010101010101010101010101121b567250000c302428350058c210000019000000000000000000000000000000000000000000fe004c4720446973706c61790a2020000000fe004c503135365748342d544c433100ff lid=1 conn=1
RRR: is lid, lid++
RRR: scr: HDMI-0/ lid=0 conn=0
RRR: prev_scr: VGA-0/ lid=0 conn=0
RRR: prev_scr: LVDS/00ffffffffffff0030e4f2020000000000140103802213780a05859b5b5494260e505400000001010101010101010101010101010101121b567250000c302428350058c210000019000000000000000000000000000000000000000000fe004c4720446973706c61790a2020000000fe004c503135365748342d544c433100ff lid=1 conn=1
RRR: prev_scr: HDMI-0/ lid=0 conn=0
RRR: lids=1 closed=0 ext=0 prev_ext=0
RRR: change = 0
RRR: NEW SCREEN ...
RRR: .... out VGA-0
RRR: NEW SCREEN ...
RRR: .... out LVDS
RRR: ...... modes 0x5583c8476c40
RRR: NEW SCREEN ...
RRR:-------------------------------- 2
RRR: 'LVDS': 0 0 1366x768
RRR: result max: 1366x768
xinerama screen 0 0 1366x768
xinerama setup............... 1 0x5583c7b343d0
@ match screens 0x5583c84264c0[0] = 0 0 1366x768 -- 0
@ matches existing zone 0x5583c7d5b8b0
move resize 0 0 1366x768 -> 0 0 1366x768
RRR: New unconfigured screen on VGA-0
RRR: New unconfigured screen on LVDS
RRR: New unconfigured screen on HDMI-0
RETRY backlight set as 0,08 != 1,00 (expected) try=0
eina_btlog << EOF
EOF
eina_btlog << EOF
EOF
eina_btlog << EOF
EOF
eina_btlog << EOF
EOF
BZ5 Agent Release
X I/O Error - fatal. Exiting
I'm totally puzzled.
Regards,
BT
