Hello, I have a laptop with a sentelic touchpad. Elive seems to manage it as a mouse with movement, but I have to click the buttons to make it work, there is no tap or other gestures.
I'm on the latest 3.8 edition, xinput shows the touchpad being found but Settings Touchpad says no touchpad detected
xinput --list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ FSPPS/2 Sentelic FingerSensingPad id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ BisonCam, NB Pro: BisonCam, NB id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
The sentelic mouse is being correctly detected by linux and xorg is using the synaptics driver to manage it.
I have enabled multi-touch in an /etc/X11/xorg.conf.d/70-synaptics.conf file and it all works properly.
The touchpad config utility still does not recognise the sentelic touchpad and reports no touchpad present.
Duly noted, thank you for the report.
Could you expand on the machine spefications?
And .... Is this 32 or the 64 bit version?
This is 64bit installed to disk.
machine is a clevo P15SM about 2014
System: Host: tanker Kernel: 5.6.0-0.bpo.2-amd64 x86_64 bits: 64 Console: tty 0
Distro: Elive GNU/Linux 10 (buster)
Machine: Type: Laptop System: Notebook product: P15SM v: N/A serial: N/A
Mobo: Notebook model: P15SM serial: N/A BIOS: American Megatrends v: 4.6.5
date: 06/26/2013
Battery: ID-1: BAT0 charge: 40.0 Wh condition: 68.0/77.0 Wh (88%)
CPU: Quad Core: Intel Core i7-4700MQ type: MT MCP speed: 1391 MHz
min/max: 800/3400 MHz
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK104M [GeForce GTX 780M] driver: nouveau v: kernel
Display: server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.3.6
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi
Drives: Local Storage: total: 476.94 GiB used: 23.54 GiB (4.9%)
Info: Processes: 217 Uptime: 7m Memory: 15.56 GiB used: 943.6 MiB (5.9%) Shell: zsh
inxi: 3.0.32
