History
- elive was running perfect
- when messing around with sound system and firefox, I messed up the audio
- JF uninstalled several PulseAudio and Pulse This and Pulse that with synaptic
- everything was then ok, sound was ok.
- rebooted
- after login & pw, I in a loop always going back to login / password can't go pass the user / password
GOOD OPPORTUNITY TO USE THE Upgrade / Smart mode install to not have to re-install and reconfigure everything
- booted with USB stick
- I am offered once in Elive and after running Elive installer to " Ugrade in SMart mode " to keep my current installation to not lose anything,,, I SAY YES
- Installation process starts but when trying to close another Window ( Mario game or something else... don't remember) I closed by mistake the Installation window so and it aborted/interupted the installation....
Now if I launch the installer or reboot with USB stick, I am not offered anymore to use the SMART UPGRADE...
Is my only solution is to re-install clean ?
installation log has been checked during installation
