Systemd filling up syslog with bluetooth resets
On my machine there seems to be a problem with systemd resetting USB bluetooth all the time. It looks to be connected to laptop-mode-settings and has only become apparant this last week.
Using "systemctl disable bluetooth" doesn't help in any way. Anybody got any pointers as my log files are getting biiiig. :sniff:
Here's the output of :tail -f /var/log/syslog":
Oct 16 07:56:37 localhost URfkill[808]: killswitch state: KILLSWITCH_STATE_UNBLOCKED new_state: KILLSWITCH_STATE_UNBLOCKED``
Oct 16 07:56:37 localhost URfkill[808]: Setting device 16 (BLUETOOTH) to unblock``
Oct 16 07:56:37 localhost kernel: [  178.867099] usb 2-7: New USB device found, idVendor=8087, idProduct=07dc, bcdDevice= 0.01``
Oct 16 07:56:37 localhost kernel: [  178.867101] usb 2-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0``
Oct 16 07:56:37 localhost kernel: [  178.870059] usb 2-7: USB disconnect, device number 18``
Oct 16 07:56:37 localhost URfkill[808]: device_changed_cb: tpacpi_bluetooth_sw``
Oct 16 07:56:37 localhost URfkill[808]: killswitch state: KILLSWITCH_STATE_UNBLOCKED new_state: KILLSWITCH_STATE_SOFT_BLOCKED``
Oct 16 07:56:37 localhost URfkill[808]: device_changed_cb: hci0``
Oct 16 07:56:37 localhost URfkill[808]: killswitch state: KILLSWITCH_STATE_SOFT_BLOCKED new_state: KILLSWITCH_STATE_SOFT_BLOCKED``
Oct 16 07:56:39 localhost kernel: [  180.875207] Bluetooth: hci0: command 0x0c03 tx timeout
The output is continous and slowly but surelyy drives up CPU usage.
Here's what "top" says:
18939 root      20   0   23240   3836   2232 R 100.0   0.0   9:44.34 systemd-udevd
14966 root      20   0   23240   3844   2240 R  46.7   0.0   5:13.77 systemd-udevd
29955 root      20   0    2544   1280    956 S   5.0   0.0   0:00.15 laptop_mode
Edit (LupusE): Improve readability with 'Preformatted text' Instead of 'Blockquote'.
Doing "systemctl stop bluetooth.service" and after that "systemctl disable bluetooth.service"
gives the following output:
sudo systemctl disable bluetooth.service Synchronizing state of bluetooth.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install disable bluetooth insserv: warning: current start runlevel(s) (empty) of script bluetooth' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script bluetooth' overrides LSB defaults (0 1 6). insserv: warning: current start runlevel(s) (empty) of script bluetooth' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script bluetooth' overrides LSB defaults (0 1 6). ~ ❯❯❯
UPDATE
Starting and stopping udevd with:
sudo systemctl start systemd-udevd systemd-udevd-kernel.socket systemd-udevd-control.socket
Seems to solve this CPU hogging but I don't know what's causing it ...... I suspect waking up from suspend scripts.:thinking:
Update the update
Connecting the charger is what causes this.
Unplugging makes all activity go away including the bluetooth activation.
This looks like a wrong setting in cpu-freq (it also resembles a bug I encountered in kernel 4.0.19-05) ... it could be because I used E2x to manipulate power-settings can anybody see if they have the same issues?
Syslogs filling up (few) sometimes happens with drivers that prints too much
Try to disable the daemon laptop-mode to see if is the one (that controls Bluetooth hooks) that makes all this printing
Yeah, well syslog is the slightest problem. The CPU hogging and subsequent overheating is.
As said it only happens if the charger is connected.
running the afore mentioned systemctl commands brings the CPU down to 3%.
so you guys a using laptops
Well certainly me ...... when my desktop broke down I never repaired it but replaced it with laptops that had screen or other defects. :happybounce:
"only if the charger is connected" this sounds to me that there can be only a possible reason: some kind of daemon that "detects AC" is triggering something, and thus, it can be probably laptop-mode daemon
So try to disable it to see if this is the cause of the issue, if so, maybe the bluetooth settings for laptop-mode should be disabled, if not, there should be another daemon that "does something" with bluetooth when AC
Hmm, turning off bluetooth and acm97 (I don't need them, they're both disabled) by unchecking them in the "laptop-mode configuration tool" seems to keep everything quite for now.
Although there is a pop-up that some settings couldn't be saved.....very unclear but it looks to have done something and CONTROL_Bluetooth is set to 0.
Rechecking ac97 indeed resets it its value to 1 despite the pop-up..
Laptop-mode is quite the syslog filler at any rate. :thinking:
As I'm reading in the /etc/laptop-mode/ confs, AC97 has no relation with AC VS battery switching
So is blueotooth the feature that should be disabled in order to not have this issue?
yes, it is. AC97 is the sound module ..... at first I thought it was my built-in modem. Only disabling bluetooth is enough to keep systemd calm.
ok, fixed package with bluetooth (management) disabled by default
