Touch-screen functionality for tablets
No, you still do not understand:
The option is 'multitouch' or 'mutouch'.
There is no functional difference between the 2 from what I see, except 'mutouch' seems to cater for different firmware. So I do not need 'multitouch' at all.
The removal of 'mtrack' is merely collateral damage when installing 'multitouch'.
I have no idea why 'mtrack' actually gets removed but is ultimately of no importance. Just keeping it installed together with 'mutouch' will do fine.
@triantares my touchscreen sometimes has "ghost clicks" in the bottom part, did you have this issue too ? im not sure what is causing it, maybe the sensitivity is too high or maybe is a hardware problem (dust, etc).
I tried to configure sensitivity but apparently is not possible, did you tried to configure that ?
for now, i just added an "activate / deactivate touchscreen " in the elive-touchpad tool:
No, never with touch but sometimes with the touch-pad (i.e my wife wants it always deactivated, prefering the track-point) and the digitizer-pen, where the latter turned out to be the (in my case) the wacom driver. I found out that the driver on 'old' 3.0 worked fine, whereas the newer drivers gave weird actions at the bottom of the screen.
So, there's a big chance it's the driver itself.
All in all 'touch' isn't very good in Linux, it just 9badly) emulates mouse clicks.
I've got Thinkpad Yoga in the wheelhouse which is practical in sunny conditions: I just jab the screen to place my cursor (which is hard to find) and use the pad. The screen is way to coarse to work with IMO.
