Weather / Calendar applet/gadget suggestion compatible with ELive?
Do you know a weather gadget that works well with our current version fo Elive/Debian ?
Am also lookig for a simple way to display the date on my Desktop ( something I was used to )
I can try them all but will save time if ou know of one that is working well
There was a calendar emodule available in the past
Maybe somebody can revive its source code and improve it with needed functionalities, since emodules are the best way to integrate something in the desktop (enlightenment)
