I've an old IBM laptop, model R51. Will this OS work in this laptop which is a non-PAE one? If you say "Yes", is there some special version of Elive that will work for me? Please state that special version's name. Thanks
Hallo @needsmusic,
In your case I'd try out Elive Stable 3.06 but running the graphics could be challenging with only 512Mb of RAM.... it all depends what you have in mind to use it for.
If that turns out to be the case, simply try one of the older 2.x versions until you think it'll be OK enough to use.
note: the stable version requires you to boot selecting the "old kernel version" (which is non-pae)
if you try the beta version, the 32bit version will be fine (they are non-pae kernels), but yeah is much more recommended to use the stable version which is lighter and better for this hardware (and more polished and beautiful desktop)
