xChat vs HexChat
I was hanging out on the debian irc Channel
when I said I was using xChat, someone said it was history that I should use HexChat
I installed it and open it, and remember the IRC channels was in ( suggested me to add elive).
Is HexcHat the successor of xChat(included in Elive) ? better ? or different / question of taste
I don't know, i didn't find so many differences. Maybe there are more plugins available in hexchat?
I used to use hexchat back on my old computer because it had a good notifications system and worked greatly under windows xp too (or was it q4os themed as windows xp? THings get confused over time ahahah)
I have it noted in a task (between other trillions) to review for compare both and decide one for the future versions
From what I can recall, hexchat seemed like the logical successor to xchat as far as features go. The advantage of hexchat is it is still being actively maintained, or at least its list of changes appeared to be more recent. I think I looked at Debian as well, to see what they included in their out-of-the-box applications.
Personally I use text-based IRC e.g. weechat, irssi, etc.
Yesyesyes we need hexchat not xchat
it's 11 years old rn. ircv3 is out and I highly doubt xchat has any of it.
Don't doubt: Test it. :coding:
Else this is a useless revival of an old thread by you.
Well the main thing is, the copyright on 99% of the individual specs is 2011 or after.
  • I only found a 2010 one and a 2004 one that were before 2011, but there may be others.
Also, I searched (with the guthib search function) for any code sending "CAP" to the server, after making sure that the code for sending "NICK" appears in the results.
From this repo:
(capability negotiation: Client Capability Negotiation - IRCv3)
(oh, and correcting myself: part of ircv3 is out.)
