Starting a 3.7.13 install on my (Vbox copy) Helix2 containg stable and 3.7.10 ..... 10am local time NL.
I opt to upgrade 3.7.10 where upon the installer simply disappears completely when I hit OK.
Waiting for it to finish, if at all.
I have vokoscreen running to record the session.
After 30-40 minutes I rebooted and 3.7.10 wasn't touched ...... so nothing happened at all.
UPDATE
Running the installer from the USB.img upgrades just fine on the same laptop that vbox is on.
Will now try with the .iso written to USB flashdrive.
Updating as I go
The Hybrid.iso also installs fine on bare metal so it must be a Vbox issue.
I download 3.7.13 32bits to a USB to test, but impossible,,
when run, it do not pass from the Boot menu,
I push the option (I have test all options)
Menu dissapear and in a while returns with the same Boot menu.
Do not continue to start.
It happened on 2 subsequent tries. I had vokoscreen running so I can show that but there's actually nothing to see.
I doubt the installer sent a log to you ...... it conked out before doing anything.
Doing 32 bit on the same virtualbox does work fine, though.
You may have probably a debug log file writed in your /tmp dir (first check this one)
or you can try to run it with debugging lines from a terminal like:
sudo su
export EL_DEBUG=3
eliveinstaller
so it should tell you where it stopped and/or why
Just testing it now in a vbox here... no bug
or you can also run from normal user (no root) "eliveinstaller-wrapper", which will include the auto update of the installer (the other command not), but it wont show you some logs
If I run that I get the infamous "the nstaller is already running ... " popup.
And then on closig the popup: trapped signal: '69' from 'exit installer' in lines '8339 2491 1'
So basically this happens if you still have a lockfile living (which can happen in a wrong exit of the installer), but the most important question is: did you booted (rebooted) the computer before to run the installer?
Yes, but as I stated it was a VirtualBox install.
There could be issues with saved states or whatever.
The first and last (3rd) install all break..... independent whether it's an upgrade or a new install choice.
For me it's not a big thing (I'll just create another Vbox instance) but might be an issue for the installer in certain circumstances. Except I don't know what's happening.
Like I said, I'm not really interested in a succeeded install but more in what is causing this.
So if this is usable let's keep using this (as a first I'll make a 1:1 copy with clonezilla) and find out what's going on.
Despite using: export EL_DEBUG=3
and then: elive-health
No scanner is recognized, only the printer.
Syslog tells me this:
localhost udev-configure-printer: Queue ipp://localhost/printers/DCP-1510-series has matching device URI Oct 7 12:38:54 localhost mtp-probe: checking bus 2, device 20: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2" Oct 7 12:38:54 localhost mtp-probe: bus: 2, device: 20 was not an MTP device
