But - I struggle getting the drivers for the gpu to work properly. Just after I posted the first post here, I encountered a crash (didn't get to take a photo of the information unfortunately).
That session I chose free gpu drivers, and was happy to see the desktop seemed to working just fine (maybe that was the reason behind the crash).
That was yesterday, but today I don't get Elive to get into desktop due to gpu driver issues.
I did managed to take some photos while booting, so here is what I did so far today:
Grub: Selected second last option, old stable kernel.
Reboot now? Do you want to reboot now to select the close-source drivers? . . . . [No]
Unable to detect driver version needed. The version of the driver that you need for your Nvidia card has not been detected. . . . [ok only]
Select the version of the Driver your graphics card needs. (current ?): [legacy-340xx Previous drivers for recent cards (older) ]
Unable to remove module: Error: noveau module is loaded and we cannot unload it. You should reboot and add the boot parameter . . . . [ok only]
[edt]
And this is the current screen.
ink group nvidia has changed slave links
Setting up nvidia-lgacy-340xx-kernel-dkms (340.108-10~bpo10+1)
Loading new nvidia-legacy-340xx-340.108 DKMS files...
Building for 4.19.0-18-686 5.10.0-0.bpo.8-686
Building initial module for 4.19.0-18-686
/usr/sbin/dkms: line 1384: /bin/strip: Input/output error
Done
nvidia-legacy-340xx.co:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.1.0-18-686/updates/dkms/
nvidia-legacy-340xx-uvm.co:
- Original module
- Installation
depmod....................................................................
And never get any further. But it's probably me doing some wrong choices . . .
Could you put this issue in a thread of its own with a header that will atract attention from those that have nvidia insight?
I don't have nvidia so can't be of help there.
It's rather off-topic for conky and an IP address, after all.
I do think the issue here is, conky is searching for eth[n], but the interface is enp0s7 ...
It is a guess out of the blue, but this kind happens often, if old configs/defaults are used.
