E16 dark theme with BIG fonts
There's some guides in the forum for modify e16 themes, but is true that most of the users don't knows how to do that, while in newer versions of Enlightenment its much more easy to modify that. But the true is that the default theme has pretty small fonts (which is good), but makes some people having difficult to see them
Just to make things easier for these users, I have included in the repos a modified version of the dark theme with bigger fonts, and for the same reason, this theme will be included by default in the next build too (3.8.8)
How to use it?
apui e16-theme-elivedark-bigfonts
then press "ctrl + alt + end" to reload your desktop, and pick it from your themes menu list
Comments welcome!
Also, since we have now a big-fonts version of the default theme, do we should make the fonts on the default theme smaller? :slight_smile: or they are already too small by default? (i dont think so but...)
Great , Thank you. Much better. At least I can now see to make other changes :slight_smile:
Are there any other themes available? I want to experiment with a lot of them
the most useful / usable / nice ones are the ones included by default in the elive repos, try all of them :slight_smile:
api e16-theme-\*
Thx :slight_smile:
Found a address with even more e-themes which are (if downloaded) in /home/"user"/.e16/themes
themesdoteffxdotus/packages/e16/
they might be older (like 2009) but since you wanna try things out ... :w00t: :w00t:
What a difference!!!! On a 34" widescreen its now pleasant for the eyes
The package has been removed from the repo since became obsolete, so please make sure you don't delete it :slight_smile:
Instead, we are going to use a new way now to have enhanced fonts, in a better way!
Please try the new way, which is very easy to betatest, and comment in the new thread:
