Succeed transffering to bullseye. using E24 ( Prefer it to E16)
Network manager connected in the background and works correctly, but I lost "wicd" gui (error msg is there is no available package in bullseye repo). So now I cannot switch between networks . Seems wicd was dependent on some python2 libraries.
nm-applet opens only once on each login session and cannot be restarted again. Its a pain in the neck. I can connect with nmtui but , would love wicd if possible
You need to replace 'nm-applet' with 'conman' for E25 if you want to have a control widget in the taskbar.
Just to remark that it is now possible to have 'network-manager' in use on E25, with a little workaround.
There's a way to get 'network-manager' to show up in the E25 systray, which will show in the ibar thus:
by way of using the following command (in a terminal):
'nm-applet --indicator &'
Where 'network-manager' will have all its normal functionality.
The trick I use to have it show up on every login (i.e NOT requiring me to manually start it every time) is to:
Go to the menu item 'śettings, apps' and add 'network' to your start-up applications.
then: -
Edit '/etc/xdg/autostart/nm-applet.desktop' and add "--indicator" to the 'exec=' line there.
You will need to be root to edit that file BTW.
