I have seen a 30 % of the boots to have this issue (in my virtualbox test machines), maybe a bug in plymouth ? maybe only with openrc as a cause ? mmh...
Could you share an Elive Trixie ISO with us? To test a fresh installation? Tank you. Have a good day.
There is no stable Trixie based ISO yet, only the --betatest upgrade as an option.
I successfully updated my i7/Nvidia PC from Elive 3.8.52 to Trixie. The first time, I ran into a libc6 error. I reinstalled Elive 3.8.52 and then performed the update again. Everything is fine now.
Hello,
I discovered an error while updating my PC (Asus Prime B550-Plus motherboard, i7, Nvidia 4060). Everything seemed to be working fine, but when I launched games using Wine, I got a black screen on some of them. I started uninstalling and reinstalling the various Nvidia drivers one by one (following this guide: Nvidia Privative Drivers installation ), but nothing changed—the issue persisted. I ran a Heaven benchmark, followed by a vkcube test, confirming a Vulkan-related problem with my Nvidia card. After some thought, I completely reinstalled Mesa; upon rebooting, vkcube worked. And my games work well.
Can you tell me which package(s) you exactly reinstalled ? I will add a forced reinstall of them in the nviida installer.
Also, do you know if your previous mesa packages where in a different version ? (maybe coming from bookworm?)
For those who upgraded, I recommend running this:
# install new packages
apui alsa-ucm-conf bind9-dnsutils gtkam hfsprogs icoextract-thumbnailer imagemagick libusbmuxd-tools linux-sysctl-defaults mate-polkit mate-polkit-common media-types
# remove obsolete packages
to_remove=$(dpkg-query -W -f='${Package} ${Status}\n' broadcom-bt-firmware cpufrequtils cxl dnsutils exe-thumbnailer gimp-gutenprint gimp-plugin-registry gtkam-gimp hdmi2usb-fx2-firmware hfsutils imagemagick-7 ixo-usb-jtag jh7100-bootloader-recovery libapt-pkg6.0 libblockdev-crypto2 libblockdev-utils2 libcurl3-gnutls libfishcamp1 libldap-2.5-0 libsbig4 libunistring2 libusbmuxd6 ndctl ntp policykit-1-gnome tftp xserver-xorg-input-mutouch xserver-xorg-video-openchrome xserver-xorg-video-sis671 2>/dev/null | awk '/ok installed/{print $1}' || true)
[ -n "$to_remove" ] && apr $to_remove
# final re-upgrade
apug
# list other possible obsolete packages (installed from other sources, or remaining ones):
apt list '?obsolete' 2>/dev/null | grep -v '^Listing' | cut -d'/' -f1
mentions: @triantares @maxinou @triki1 @earl31515 @linux23dragon
First, I installed the Mesa 550 driver using the tutorial linked above, disabling the Nvidia driver in GRUB, and then I followed the recommendations.
Here is the list of my packages; the i386 ones are included. When installing Lutris, a DXVK error occurs. I concluded that the Lutris package wasn't installing the i386 packages. If you don't need them, you can ignore them. The Lutris repository version is no longer maintained; we are prompted to download the new lutris .deb. Download Lutris Oh, another missing package for Lutris: sudo apt install python3-protobuf(lutris
2026-09-06 22:26:18,590: The Battle.net source is unavailable because Google protobuf could not be loaded: No module named 'google'
2026-09-06 22:26:19,053: Starting Lutris 0.5.22)
for nvidia:
glx-alternative-mesa libegl-mesa0 libegl-mesa0:i386 libgl1-mesa-dri libgl1-mesa-dri:i386 libglu1-mesa libglx-mesa0 libglx-mesa0:i386 mesa-libgallium mesa-libgallium:i386 mesa-opencl-icd mesa-utils mesa-utils-bin mesa-vulkan-drivers firmware-nvidia-graphics firmware-nvidia-gsp firmware-linux-free nvidia-kernel-common firmware-linux-nonfree nvidia-kernel-dkms nvidia-kernel-support nvidia-modprobe
for vulkan:
libnvidia-glvkspirv libnvidia-rtcore libvulkan1 libvulkan1:i386 mesa-vulkan-drivers nvidia-vulkan-common nvidia-vulkan-icd vkmark vulkan-tools.
mesa:
Trixie/nvidia 4060 ok
