ok, thank you Thanatermesis
its dam cool btw !!!
ahm...... dont see any installer icon? e16
where is it ??
these menus are different but you can found all
it is in the elive menu
next, next, next ![]()
HOW COULD YOU DO THAT: WITHOUT AN ICON!
am from Mac, keep in mind! = no icons - no computing ![]()
in German they call us:
mousepushing iconclickers (sadly not so funny in english)
it's awesome and mo'fuckin fast gets me exited ![]()
finally working - fast as hell !!!!
The dam harddisk has some to do right now : " drrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr" ![]()
seriously, it works now how it should be good job ! (almost finished after less than 20 min)
SADLY first boot:
EXT4-fs (sda2): Cannot change data mode on remount
You are in emergency mode.
Give root password for maintenance
( press Control-D to continue):
= Control-D = loop
ok, the data=writeback should be definitevly removed, i will do that now
@Rebel450 boot in live, mount the partition of your installed elive system, then edit the file etc/fstab that you have on it (maybe "sudo scite", or enter in admin mode from thunar first), and remove the ",data=writeback" part, like:
UUID=6465b1c1-8232-4c28-ae29-0c15c9c0f2f7 / ext4 defaults,commit=60,noatime,nodiratime,data=writeback 0 1
to:
UUID=6465b1c1-8232-4c28-ae29-0c15c9c0f2f7 / ext4 defaults,commit=60,noatime,nodiratime 0 1
then umount and reboot, it should boot fine
neeeeext! ![]()
PD: @triantares I finished to implement the new sudo structures, going to test it now ![]()
PD2: we* are doing an amazing job reporting things from this 248-posts-long chat ![]()
Can somebody confirm this is fixed?
Yeah, total frenzy and madness ..... as long as it works, I'm cool. ![]()
Maybe start a new one now ..... 3.7.1 Where art thou?
yes, i personally don't like to have a flood of text to read (and to answer) lol, but in terms of efficiency, it works well ![]()
the other option could have been to use the chat, but this thread can do the same and including more features (images, scrolling-up-in-history, offline-mode, etc)
finishing the remaining things for it before to build
I think that I will leave teh UEFI implementation for 3.7.2, since that could take more time
or not? ![]()
done, is still the same
Ha! I found a friendlier way to ask for nvidia drivers & for E desktop! ![]()
Try it @Rebel450, run from a terminal:
/usr/share/doc/dialog/examples/menubox
this example allows to not be confused with the Enter with the Spacebar ![]()
so you removed that entry from the fstab, saved the file correctly, and it doesn't works? ![]()
@Rebel450 I would say: play with the different E flavours to be familiarized with them while waiting for 3.7.1 which already includes many fixes
could be more simple
mhm.
but why is it that difficult on my side, the others seems not to have so much issues?
I will give it tomorrow a spin on a more simple build desktop pc, may be its better then...
for now I have to go.
Back online tomorrow around 9:30am (and You?)
GN
Well, you can in fact reinstall again the same way, that data=writeback is removed now from the installer, so i dont see a reason to not work (unless was another thing)
i will continue working until 5 am probably lol
@Rebel450 this way makes it more userfriendly, don't you think?
no spacebar required!
and this is the famous "standard and good filesystem" that the rest of the world uses ![]()
j/k
