3.7.0 betatesting experiences
Uncheck "elive-configuration" in the list box you get.
I'm not sure whether @Thanatermesis uses "brightnessctl" to manipulate the backlight but I found it requires "sudo".
Not very logical considering screen brightness is a very USER thingy but then it is "systemd" rearing its ugly head. :face_vomiting:
Use "brightnessctl" to discover max and current settings, "sudo brightnessctl s xxx" to set brightness desired. (xxx is in this case a number.)
Yep, in fact happened to me recently, I had an external disk similar to yours used for year for work, in fact with a similar (simple usb mini?) cable, but it started to fail in a level that become totally unusable (similar to your, but only showing errors in kernel messages, no crashes), I put it in the trunk thinking that was totally useless. One day I tried to use the cable that I had from other similar disk (but not a normal usb cable, these not works), and surprised! it works perfectly now and its in full health! the problem was simply the cable !
From e16 ? it is reproducible ?
you need to select it from live before to install and it should be included, but you can also "api enlightenment" to switch from e17 to it, note the list that e17 problems has (said in live mode)
For now it only works in live mode (if worked), requires sudo whithou password if you can configure that, I will check how to implement it for the installed mode.. noted
It should appear only in your first desktop setup (first installed boot), but i have noticed that for the songs too, but later it worked... I don't know yet what could cause it, will need more tests to reproduce the problem
The systray ? it should work without problems, but only shows up when its used, for example press "alt + esc" which opens kupfer (launcher) on the trayer
brightness ? seems like is not well supported in your hardware, try if the birghtness gadget works for you in E22 from live mode, otherwise you may need to google if you need a special setting or driver (or package to install)
there's different ways to change brightness, acpi call, /sys call, /proc call.. even a xrandr command which not works for everybody, being said that, every "brightness tool/gadget" uses a different code (or all of them, which is the ideal) to make it working, the future will be being able to do it from the E22 gadget, so first try if works from it, otherwise, that code should be then improved
:dance:
yuck ati... but good to know that works for you :slight_smile: , ati is always a hard one (probably the reason of the brightness issues), you may need to google for that about brightness
yep, as we can see it in the .e16/e-something.0-0.cfg file, you can add a NOPASSWD entry in the sudo conf to make it working for now
and yes, i dont know why it requires root privileges but this is how it is made
so i'm not the only one with random hardware lying around my room.
Thank you a lot. Did not think about that!
thanks
It's not something i'm going to do :eyes:
I realized that just a few cm difference in length may make the difference between a well working drive and an unreadable one
I will try to reproduce it. Tell you in a few minutes!
Tell me if i may do anything about that
This may explain what i mean better than me:
I thought also play and stop but i was mistaken they actually work properly!
Checking it out thanks!
I dont see any problem in the systray :thinking:
Not the systray... in e16 when elive was just installed there was a widget listing the cpu %, the amount of RAM used, the most resource intesnive processes... And suddenly was gone!
@Thanatermesis I cannot get arandr personalized scripts to run from .screenlayout/xxxxx.sh other than maually using "source".
checking .xsessions-errors I see a line stating "cannot create ~/.config/elive/elive-tools : Permission denied :thinking:
Is this the cause of the ever returning configurator on startup?
You mean setting up a "Cmnd_Alias" in /etc/sudoers or another user?
No it's not.
BY THE WAY the password creation field in the installer does not hide the password!
Its "conky" and its launched as a demo in live mode, you will need to run it yourself in the installed system to have it
I wonder if I should include it by default (forced for everyone!)
this is because e17 includes a wrapper which launches it before to run the desktop, mmh, maybe i can include it in e16 too :thinking:
cannot create permission denied?? is this directory owned by root or something similar ? :thinking:
No owned by me and set as 40755
Maybe needs to be set to 40757?
This is the installed version, just to be sure were talking the same.
improving this now :slight_smile:
No, that's correct, mmh, something is trying to use this dir and there's a wrong permission, maybe -this- is the issue with the "audio song" configurator that is asking all the time at start @stoppy98
can you mkdir ~/.config/elive/elive-tools from user ?
Nope.
Permission denied ........ strange!!!!
then we need to know what causes this :), check its parent directories permissions too
about brightness, @stoppy98 & @triantares, add for now a configuration like this example:
~ ❯❯❯ cat /etc/sudoers.d/privileges_network
for /usr/sbin/brightnessctl
Al the same. Owned by me and 40755
