All the elive versions has this feature , just boot a new ISO and run the installer, everything is guided and automated
We are talking about "upgrade" or "migration" mode?
well, in any case has both modes
but the "migration" mode is not so tested (every distro uses a different setup), but the idea is basically to "convert your other distro to an elive one" (saving users, settings, etc)
then, that said...
would it not be especially for you as dev/maintainer more easy to put the major changes
into dist-upgrade
(don't beat me - just a thought of mine ...)
the thing is that "not everything is possible" by just including changes in teh packages, for example the installer runs a lot of administrative commands and configurations and stuff, packages doesn't include that
yes it is technically possible, but the amount of work requried for that would lead to a 100x times slower development of elive, and probably with more bugs than fixes lol
I've tried it twice (with shared Ubuntu USER on ext4) now but didn' it work. Just left me with wrong USER permissions so couldn't log in.
I didn't check thoroughly but had the impression that it had to do with different numberings for the USER.
There are some differences between Ubuntu and Debian, just tiny details
but they are there... (e.g. naming Ubuntu = not case sensitive | Debian = case sensitive, ect, ect)
in the stable version of elive that not works because most of newer distros uses a non-compatible ext4 version (unreadable by elive 3.0) to ext*
but maybe its just a problem in the feature
this is included, but maybe is not working correctly will be needed to betatest that (but better in a virtualmachine since we can go back to the previous state, reinstalling other distros is much more work)
The only things that you can translate in eltrans is elive things, basically because its own software which its repackaged "on-house", so translations are re-incorporated bla bla...
For translate things that are not elive, you must send your translations to the author of the application itself, and like you said, everybody else will be benefited
If im not wrong, eltrans includes an explanation of how to do that for Enlightenment itself (so the same apply to terminology and any other soft) , but i dont remember what it says lol
Yep, i do (Clonezilla ) still have a copy.
Do you really mean the whole /etc directory?
That was Ubnuntu 16.04 BTW. Still got another1:1 copy running on the yoga ideapad (the one with the gpt disk) on its /dev/sdb1.
Running out of time though, have to get up at 5.30 and sail to Zeebrugge, pack my hike stuff and vote (EU) then load my ship Friday, clean it and sail to Brugges. Next morning at six on the train to Austria for a week. Suspect you lot will be on 3.7.3 by the time. I'm back.
yes, to use the tool "meld" (included in elive, amazing tool!), to compare the directories (or better just the files like passwd, shadow, group), to see if there's an issue with the UID's as you said
but it can be a slow task / process, maybe better that just me do tests here, also, efi stills better implementation
I think that ther's some "virtualbox images" that can be downloaded, ready to use images
